Nyborg Garage »
https://forums.nicoclub.com/nyborg-garage-u125912.html
Wed Feb 04, 2009 12:57 am
Hi.
This seems like a great forum, so i thought i should introduce myself, and my car/engine.
It all started when I got a piggnose s13 cheap, all it needed was an engine overhaul.
So the plan was to pull out the engine, and replace bearings, pistonrings, gaskets, and such. And then sell the car.
But then a friend of mine wanted to swap his T3-T04 for my stock t25 (he had a 1.5 liter honda with an "ebay kit").. I could not turn down that deal. The turbo itself was "free", but of course then i needed a new top mount manifold, ext wastegate, bigger injectors, stronger clutch, ECU tuning, FMIC, custom exhaust, and so on.
So then i desided to take it even further, and i milled the head for a C/R of about 9,4:1. I'm used to work on Hondas, and high compression, big cams, big turbo, and high revs is the way i like it Pluss i love E85 If course high comp pistons would be better, but I was on a tight budget. I also did not balance anything, og change the rod bolts, so I will not rev it to far yet (or?).
Since i milled the head so much (0,057") i also bought adjustable camgears. But the the timing marks was dead on, so that was not really necessary. But I am going to adjust them on the dyno to figure out what valve times workes best (most likely with a ca18det exhaust cam on the intake, and exhaust side).
For tuning I use the ostrich emulator and liveedit/romeditor. But I will uppgrade to NIStune later on.
On the first test run I blew the headgasket. I had a 5psi spring in the wastegate and no bleedvalve, but I had mounted the 60mm wastegate the wrong way, so it did not open much And I was to busy looking at the AFR, so I did not notice the boost climbing to 1.5bar + ~22psi of boost combined with old low octane fuel, high C/R, and stock igniton timing was not smart If I only had the patience to wait for my codriver and some E85
So at the moment I am waiting for the money to buy a cometic headgasket (coments?), ARP headstuds, and that new cheap lightweight flywheel (mostly becouse i have a strange bolt pattern on my flywheel, and both XTD and F1 racing clutches don't fit).
I also have plans for some betters cams later on, but I have not desided on what cams I think will suit my engine best. As for now I think the solid lifters are to expencive, so I might settle for 270, or 260 duration and 8.8mm lifte Tomei cams. Or maybe greddy 264 duration and 8,5mm lift. There's not much more to choose from, is there?
Well, here are the pics.
Both my cars, and the ca18det in parts
Milling the head (did this my self).
Big enough? :p
Starting to look good.
"emu"
Modified by Nyborg Garage at 5:16 AM 2/4/2009
Modified by Nyborg Garage at 5:20 AM 2/4/2009
