I have a pair of NX 2000 calipers, AD22VF's, that I'm going to be putting on my 90 B12 Sentra and have run into a slight problem and need to find an answer.
I have already cleaned, rebuilt and painted the calipers and mounting brackets but I can not find the rubber slide pin bushings that fit.
The caliper uses a short rubber bushing and a long rubber bushing that goes into the mounting bracket. I believe the long bushing is designed to go all the way through the bracket but the replacement one's I bought are too short, about a 1/4" shorter than the one I pulled out of the caliper bracket when I bought them (from junkyard).
I tried a different part number and the long bushing was the exact same length.
Nissan has a caliper overhaul kit but it contains the piston seal, dust boot, metal ring, bleeder cap as well as the slide pin rubber bushings, problem is I don't need all that other stuff plus they want $27 each side for the kit !!!
So my question is, is the long slide pin bushing actually supposed to go all the way through the mounting bracket or not??
Here is what the rubber slide pin bushings look like:
here is a rebuild kit from another company I found in a how to on rebuilding the calipers, I believe this company is outside the US:
Here is one of my painted calipers and bracket:
another view:
