float_6969 wrote: ↑Wed Oct 19, 2022 4:33 am
Holy necropost! That was a dig to find this one. Love that you're searching though!
Yeah, Oldie but goodie! Purchasing a 2004 vehicle and getting good info is a challenge, but NCIO is up to the fight!
As a side note, I have found that apparently two different bolt assemblies were used. Both bolt versions are the same length though. I found three different Xterras in the U Pull It (UPI) and I bought all three bolts. Turns out one was a non-Nissan part, and the other two were Nissan parts. One had a standard nut on the end, and the other had the "anti-rotate" tab welded on the nut. I used the nut with the tab.
I think the torque rating in the FSM is too high for this bolt at around 35 ft/lbs. It almost felt like it was going to strip so I stopped at 25 ft/lbs. I'm going to UPI tomorrow and I'll check a few more, but I'm feeling good about this fix.
Thank you for the assistance!
