nekoabandoned wrote:compression checked out and as stated above we hooked up a spare injector(known to be good) to the harness and wired a fuel pump straight to the spare injector . there wasnt a pulse sent to the injector, im guessing its either the ecu or the cas. is there a way to test either so i dont end up wasting more money o.o
did you try pulling the rail with the injectors and and seeing if it sprays when you crank it? another test i could think of doing is with a ignition scope but i dont know were you could rent one of those. the only other thing i can think of is do a voltage drop test go right off the ecu back probe the pin for output to injector and also back probe the injector wire thats from the ecu, turn the car on and see what you reading is. also go on the other side and do a voltage drop. this is kindof hard to explain online but ill attempt to do my best and ill draw a picture of what i think it wound look like and were you should do the voltage test . kindof hard to say with looking at a wiring scamatic for the car. also check the available voltage at each wire by back probing each side and putting one lead on it and the other on battery ground. do all of these test with the car on engine running. if these sound to confusing just let me know ill try to explain them better. and if you really need help you can call my cell cuz im at some family event and would really love for a reason to step otta the room 603-852-2852
<<<<VM>> <<VM> +--------------IJ---------ecu------common ground-
