Hi.I am new here. I got an 89 240sx automatic coupe (124K miles) for free - previous owner put on about 50 miles after he bought it with a rod knock ($1200). I need a motor, and beside the obvious same year/model, I would like to know what other vehicles have compatible [nearly drop in] motors.
Stock motor is KA24E. What years and model could I find this motor in?
I wouldn't mind upgrading to the KA24DE. What years and models? The car isn't perfect by far, but the rocker rust is probably the worst of the body damage. a small dent between the tail lights and a scrapped hood and headlight covers aren't too bad with easily replaced sheet metal.
After reading classified ads, I found several 240sx's in need of new motors - rod were the only listed issues when the problem was mentioned. Are the rods the problem, or is there a lack of maintenance rash going around?
I had a 1980 200SX with the 2.0 liter fuel injected engine, and I never had that thing apart. I even put it and the 5spd into a 1974 Chevy LUV pick up truck when the 200 rusted to bits. The motor had around 500K when I let the junk yard haul the rusted out truck away. Besides 2 or 3 alternators, and 3 or 4 water pumps and 2 clutches [upgraded to Centerforce for the 2nd one I installed], and the usual oil change and tune-ups, that thing loved to run. I drove the hell out of it! Started every time and still passed emission (for a 1974 pick up truck anyway). So I know the Nissan 4 banger oughta live longer than 124K. Very easily.
Could someone help me see the difference between the S13, S14 and the S15 vehicles? I am assuming this is the body style?I have read a more than a hundred posts, but haven't found the answer to this question.
http://www.risingsunengines.com/ quoted me about $1100 for a new long block with a remanufactured head, shipped. This certainly isn't a bad price. But I am still looking cheaper, and closer to Wisconsin, with the possibility of the dual cam upgrade.
Maybe someone has a good transplant candidate motor in my neighborhood that they would like to have hauled away?
I do have one other item about this site, and that is none of the buttons seem to be showing on my computers. I've tried at work and home with no luck. Avatars do show, but none of the buttons and nearly all of the pictures embedded in posts do not show - only the red X. Any ideas on this inconvenience/problem
Thanks for your words of wisdom. I look forward to reading more and more posts as time allows.
