nub question
GEO
Car: 95 240sx KA-T
if I disable over-drive on my transmission will it help my acceleration?
89240sx
I'm assuming you have an auto trans by the question.... I've noticed that if you leave it off you can actually use it to your advantage by turning on at the right point and give yourself a bit of a boost.
GEO
Car: 95 240sx KA-T
That can't be good for the transmission.
WongFeiHung
Just get a friend to time you running...
Under normal driving, doesn't OD just make it shift at lower RPMs?
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
OD is like another gear, like a 4th or 5th gear, you sue it if you are towing something or pulling a heavy load, but i don't know if it helps your acceleration, i doubt it though.
89240sx
It's a taller gear and the OD button just tells transmission to use taller gear... I dont see how it would be bad for the transmission but if it goes out then I'll probably either do a manual conversion or get this one rebuilt with a shift kit.
nlzmo400r
Car: '02 Nissan Altima QR25DE
'93 Nissan 240SX hatch KA24DE
it wont help your times at all. With overdrive off, imagine you're driving with a lock keeping u from using 4th gear, its the same thing. With over drive on, your car will shift into 4th gear, simple as that. My car has 1,2,3 and then D. D is my 'overdrive' or 4th gear, leaving it in 3rd does nothing but keep u in 3rd gear and not letting u get to 4th. The only way having OD off helps u in a race, is from a roll. If i roll from 6omph in drive, and punch it, my transmission has to down shift to second first. However if im cruising at 6omph in 2nd (by keeping the shifter in '2') i can nail it and go and not have to wait for a down shift. However, i must put it in '3' soon because at 72mph if im still in '2' i will hit the limiter (simply cause the transmission can't go to 3rd gear. Get it?
themadscientist
If you nail it the transmission should kick into power mode and jack the shift points up so you shouldn't need to switch it off. by the way vengeance, you got a cute butt.:)
GEO
Car: 95 240sx KA-T
SO should I drive wiht it on or off?
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
on, it helps gas mileage
Sliding_S14
Car: Sliding from the Side
cant consintrate that phat ***bouncin in Vengeance's sig needs a disclaimer on it"do not operate heavy machinery after viewing"
