Nsport Turbo
Charlie240sxt
Car: 95 240sx SE Ka24det!!! 98 audi A4
I know thay have a T04B-R but what i want to know is what RPM you get full boost and and was askin if it would be worth it to up for the Ball Baring upgrade for $400 and what would you get full boost at with a BB T04B-r Thanx
And yes a searched didnt find a real info
DaveEEE
when i was stage 1 I hit 7-8psi at like 3900-4000.
dave
Structure240sx
some gears and sometimes i start spooling at 2500 rpm but usually its like 300 and yes full boost (8psi right now) by 4000 or before
Charlie240sxt
Any one know what RPM you would get full boost if you upped for the Ball baring turbo and would it be worth $400 bucks to
Structure240sx
i've heard somewhere they can spool up 300 rpm sooner i would think maybe 500 tops not worth it to me. cuz i also read here on nico that ball bearing turbos cost a lot to rebuild.
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
i'm interested in getting an Nsport kit now...but i'm really not interested in tearing down my engine and rebuilding....would i be safe at 8 psi given taht my compression is good and all? the most i really want to do is replace gaskets and stuff...then again, how much would it cost for a port & polish/valve job at a machine shop?
SingleCamSam
You'd probably get quicker spool by just getting a T3/T4 with a .63 turbine rather than spending all that moola for the ball bearing upgrade. I'm not sure if that's an option with N-sport though.
Structure240sx
u'll be fine at 8psi with good compression and u wont be dissapointed. just retard ur timing to 16 degrees and u'll be fine with the fmu and walbro pump
