mello88 »
https://forums.nicoclub.com/mello88-u18450.html
Thu May 29, 2008 8:11 am
Yeah so yesterday my house got broken into, door was pried open, my 32" LCD monitor and a Wii was stolen. Great news right ...
Anyways I figured since I already had such bad luck already that karma owed me big time and would allow me to get the RB fired up. I got the wiring done earlier in the week and had it turning over day before yesterday. Found out I did have both spark and fuel, so I played with the CAS for quite a while until I realized I had it 180' off to start with (whoops).. After I fixed that, I got it to fire up! Sounds pretty nasty dumping straight out of the turbo!! Had a big oil leak from one of the AN fittings for the turbo oil feed, and a vac leak from the CANP fitting, fixed those minor issues and let it idle for a bit... Set the timing and reset the fuel pressure. Let it run for a little while to make sure no issues & so far everything seems great.
Yes, I have some pictures of my messy engine bay & hilarious looking snorkel intake (just used a long FMIC 90 off the J pipe with the MAF on it, it sticks up about 2 feet above the bay) and even some start up video,,,, but I have no way to get them off my phone here at work! I know, I know, Tonight I might get them uploaded...
Anyway I just wanted to share the bittersweet news with my fellow RBers!!
Still to dops pump feed lineefan installfabricate downpipe & exhaustfabricate/modify FMIC piping for HKS mani & t3t04e turbofabricate FMIC mounting brackets & enlarge hole for pipingbolt up LCA'sinstall clutch slave line & bleed clutchreattach driveshaftfill transput dash back in(does this list EVER end?????)
Then I should be back on the road! so ****ing stoked!!!!!! Thanks for all the help guys.
