nuts510 »
https://forums.nicoclub.com/nuts510-u34687.html
Mon Feb 16, 2009 4:00 am
sometimes cars have a way of being frustrating, if you're interested in a good automatic transmission of got one with only 80,000 miles on it, when you replace the transmission it would probably be a good dill to install a transmission cooler, there's a service bulletin on these cars about the transmission cooler deteriorating with time resulting in them that transferring the heat away from your transmission. Also if you decide to bang on your starter don't beat on it with a 5 pound hammer through years of experience I have found gently tapping on them while somebody else is trying to start the car can free them up but it's only temporary my boss used to pick on me about my magic hammer because I'd go out and bang on starters to get cars started so I could pull them in the shop to fix them, also make sure all your connections between the battery and starter are good that can cause problems to
