dhen »
https://forums.nicoclub.com/dhen-u100551.html
Thu Oct 30, 2008 2:50 am
Hi,
I made an oil cooler kit and put it on my engine. Everything seemed fine until I accelerated hard. I heard a noise, but my car's old and makes a lot of noises. Anyway, I could feel the engine slow down as I was accelerating. I kept driving at about 4,000 RPM and something was definitely not right. I noticed I had no oil pressure, so I coasted down the hill I was on.
I wasn't in the best place to stop, so I tried to see if I could limp the car home. It would run but stall on idle, so I kept turning it off and coasting and then starting it again. I tried this for about half a mile before I figured that I had to stop. I walked to a gas station, bought oil and filled the block. Started the engine and it idled but it sounded dry and had no oil pressure. I waited a minute and no change, so I turned it off. About this time I noticed a huge oil puddle under the car. The f-ing adaptor plate had popped off the block! You could feel pieces of stripped threads on the bolt where the adaptor was supposed to be.
I think this happened because I overtightened the adaptor plate. The adaptor plate is aluminum. What are the threads on the bolt where the oil filter attaches made of? It was dark so I couldn't check if the bolt on the block stripped or if it was the adaptor plate. I really hope it was the adaptor plate, since that's only about $15.
Reading this, do you think I just screwed my engine up? What do you guys think I should do?
Thanks,
Darian
PS The oil cooler solved my heating issue, not that that matters much now.
