mej30guy »
https://forums.nicoclub.com/mej30guy-u105785.html
Wed Sep 24, 2008 2:59 am
I pulled the engine cover last night and took a peek. The ideal place to attach the new ks is on the driver's side towards the back of the engine. However, that bolt also secures the bracket that supports the transverse tubing, (for lack of a better term) so it won't bolt directly to the block.
In front of those bolts, there are two bolts that sit side by side, directly on the block. I think those are the ones, but it doesn't look like there is enough of the block underneath the bolts to cover the entire bottom of the ks, which may not be good enough for an accurate readout by the ecu.
Another spot that looked very promising is just under the left hand throttle cable, toward the front of the engine. There is a bolt that sits directly on the block, with enough of a base under it to fit the entire ks. Unfortunately, it may be too far away from the ks ecu connection. If the harness is long enough to reach, this may be the spot.
According to the experts, where is the best place to relocate?
