dickie »
https://forums.nicoclub.com/dickie-u32299.html
Sat Feb 07, 2009 7:02 am
misfiring would cause the engine to shake all of the time like that.
check to make sure all your cylinders are firing by pulling spark plug wires with the engine running, one at a time and then replacing them. if the idle gets worse, that cylinder is fine. if it doesnt change the idle when one wire is disconnected, youre not getting fuel or spark on that cylinder
