I meant injectors...JonPowell wrote:Do the igniters have power to them?
i have this same problem a while back, the engine only runs when you spray starting fluid into the intake. check the red wire by the 6-wire plug, make sure the white/black wire on the rb 6-wire plug by the battery, and see if it get 12v signal. that's the wire that feed power to the injectors.apex_7 wrote:yeah, they've got power and ground, just no signal. I really appriciate you taking the time to ask these questions because it is possible to overlook some of this stuff. So keep it up til you run out of ideas
I hate to say I told you so, but I told you so......I am glad it finally got started for you though!JonPowell wrote:
Trying to trouble shoot with you guys here instead of jumping to the hard stuff, I always like to rule out the easy cheap stuff first.....It would really suck for you guys to buy a computer and find out that the injectors had no power to begin with.
it's not the red plug...it's a typo in my post...it's the rb 6-wire plug w/ with the ka gray oval plug by the bttery.KUILLIN_DRIFTER wrote:ok this is what i have..
12v signal to injectorspulse signal from ecu to injectorsfuel pump, pumps but i have no idea about the fuel pressure.
12v to ignitonsignal to ignitionspark to all cylinders
tried to check the red wire with red plug but can not find the plug. Starts with fluid but will not stay on. i'd like to reset the ecu because i think there's a possiblity it might be in diagnostic mode but my ecu has no led light. seems like everything is working correctly but a fuel problem exsist. i also got it started when i push started it. i'm lost??
Bluefire wrote: brown.
