Now my J30 isnt blowing cold air and the ?A/C belt? is making a horrid noise
unc1334
Car: 1993 Infiniti J30 Gold Package
Alright, so I posted a few days ago about my air not working at all, as well as my headlight issue. Thank you for the advice, I got my air fixed, or so I thought, and I ordered the headlight relays. So the other day driving back to school everything is fine for once. Air is ice cold, lights are working and then bam! It's like I went over a bump or something, my A/C just stops blowing cold air. It's blowing air, but not cold air. If i turn it off, it sounds like something is dragging below my car, such an awful noise, and I turn it back on and nothing HELP
gr8scott72
Car: 1994 Infiniti J30t
unc1334 wrote:Alright, so I posted a few days ago about my air not working at all, as well as my headlight issue. Thank you for the advice, I got my air fixed, or so I thought, and I ordered the headlight relays. So the other day driving back to school everything is fine for once. Air is ice cold, lights are working and then bam! It's like I went over a bump or something, my A/C just stops blowing cold air. It's blowing air, but not cold air. If i turn it off, it sounds like something is dragging below my car, such an awful noise, and I turn it back on and nothing HELP
My first guess would be the pulley that holds the a/c belt on has siezed up. You can check by taking the belt off and seeing if you can rotate that pulley freely. If it doesn't turn freely then that is your problem. You can check the actual a/c compressor that way as well.
