Now I have to install this Alternator
djazzmo
Car: 2002 Infiniti Q45
On a previous post I told you all about trying to get an alternator from Car Parts Wholsale. I got a lot of advice about how I should have bought a OEM instead of a rebuilt but money is funny right now so I am going ahead with the rebuild and hope for the best for now. BTW it took them a full 7 days before they shipped the parts (totally unacceptable in my opinion - they will not get my business again). It took another 7 days to arrive in my city. We had an ice storm so it took another 6 days before UPS would deliver. It will be another couple of days before it is warm enough to tackle this. Add another 7 days for the prior suppler (Parts Train - won't be using them again either) to figure out they didn't have the parts and I am well over 4 weeks to finally get to this point.
Ok I have replaced alternators on other cars so I thought I knew what I was getting into. Now I am looking at the FSM in detail and OMG. This looks like its going to be an all day job. I have to drain the coolant, remove the fan assembly and shroud, drain the fan motor.
I'll admit my skills are somewhat less than average at best, nowhere near the talent I see on this board. Don't laugh but I am a little intimidated by the job. Anybody got any advice? Anything goofy I need to watch out for? Any shortcuts?
slybydesignq45t
Car: City Bus
If you want my 100% honest opinion, if this looks like its going to be a tough gig, try and find an indie that will allow you to watch and have them do it for $200 max. I know it is tempting to try it yourself, but from what you described you may want to lean on caution and have it done right. On the G50 it is extremely easy to change, but on a 2002 it may not be that easy. If your really bent on doing it yourself, then give yourself plenty of time. Seeing that you have the FSM you should be straight, plus the extra knowledge learned will go along way down the line. Tools tools tools....make sure you have all the right stuff handy....
Trumpkin
Car: 1995 G50
djazzmo wrote: drain the fan motor.
after reading this statement-better have someone else do it.
Q45tech
I almost never do my own parts replacement. I just enjoy the diagnostic part not the actual work, leaving it to those that do it everyday.
djazzmo
Ok that's cute. You caught me . I meant the fan fluid reservoir tank.
So now is there any advice?
Trumpkin
Car: 1995 G50
Q45tech wrote:I almost never do my own parts replacement. I just enjoy the diagnostic part not the actual work, leaving it to those that do it everyday.
I'm surprised. Doing it is most of the fun!
Drake57
Car: 1992 Q45, 1990 Q45 (parts), 06 Sportster XLC, 85 XJ6, 08 4Runner, 89 Suburban 4WD, 75 Honda CT90
[QUOTE=djazzmo](Parts Train - won't be using them again either)..QUOTE]
Ditto my experience with them (not for Infi parts) - No one ever said it was a fast train - they make IOS look like a speeding bullet.
Drake57
PS ***Disconnect the battery*** first of all!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Trumpkin wrote:I'm surprised. Doing it is most of the fun!
Not an alternator, and certainly without a lift!
djazzmo
maxnix wrote:Not an alternator, and certainly without a lift!
Why would you need a lift for the alternator? Doesn't it come out from the top?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
On a VK, probably. On the VH45DE, they hid it real well.
Weird you would need an alternator so soon.
djazzmo
maxnix wrote:On a VK, probably. On the VH45DE, they hid it real well.
I thought the same thing. Others on this board say they got over 200K on their OEM alternator. My car is just over 103K but I had it checked after it showed all the classic symptoms like the traction control and VDC shutting off after driving a few miles. This has gotten progressively worst and now I can see the lights starting to flicker on the few occasions that I have been forced to venture out after dark.
Q45tech
I keep pointing out that the period from 1990-1995 was the most reliable mechanical and electro mechanical era for every auto manufacturer. After 1995 electronics was used to replace mechanical robustness.Computer software allowed cost reduction by running closer to ragged edge of design.
Almost every 97-99 alternator has been recalled and replaced at least once due to extra heat from top mounting vs relatively cool bottom of engine...............heat rises in traffic.
Who in right mind would top mount an alternator.....................kind of like ZR1 and LS400-430 mounting starter under plenum.
Newer is only better while still in warranty.
Longevity of used cars is much of the problem in the crash of new car sales as 3-6 year old used cars seem ok to former new car buyers.
NightRiderQ45
Car: 1998 Infiniti Q45
Yeah, it's crazy how the "all mighty" OEM alternator needs to be replaced.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Or under known-to-fail power steering pumps like Lexus, thus doubling the cost of a failed PS pump.
Modified by maxnix at 3:34 PM 2/6/2009
Q45tech
LS Power steering pump fails from lack of PS fluid mainteance too many rely on turkey baster exchanges without a chemical solvent flush. The filter screen plugs up from degraded PS fluid and starves the pump wearing it out fast. Proper T3 mainteance makes them last forever if caught in time unfortunately too many LS stay with dealers until it is too late.
I believe we have changed hundreds and hundreds.
qship96
Car: 1996 Infiniti Q45
Dennis, that comment probobly caused Brian to sprout wood!
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Q45tech wrote:LS Power steering pump fails from lack of PS fluid mainteance too many rely on turkey baster exchanges without a chemical solvent flush. The filter screen plugs up from degraded PS fluid and starves the pump wearing it out fast. Proper T3 mainteance makes them last forever if caught in time unfortunately too many LS stay with dealers until it is too late.
Mr. Toyoda say "You supposed to buy new Lexus after 100,000 miles, gaijin."
