Little Tank »
https://forums.nicoclub.com/little-tank-u97939.html
Wed May 28, 2008 7:17 pm
Hi Mechanics,Found the truck site! I just did a rear brake job on a 4X4 D21 92 Hard Body. Everything went well until I hit the brake pedal on a test run. I changed out the left rear drum since it was scared beyond repair. I'm pretty deaf when sqeaks start. Once it was past repair I could hear the noise. The other drum was smooth as glass. Didn't do anything to it. Replaced both set of rear shoes. When pressing the pedal at high speed I get a chatter with a shake like an 8 on the Richter scale. At low speed it feels like one of the drums is egg shaped as it shakes to a stop. When putting on the shoes it appears as though there was only one way to put them on with the emergency brake cable shoe to the front of the truck. Any thoughts as how to fix it? Bought the parts from NAPA. Everything looks good. any help would be appreciated.ThanxGerald the Little Tank
