Noticeable Power after 5500 RPMS!!!
youngun21a
Car: 240sx 1993 Automatic
Since my rebuild, I have notice that after 5500Rpms I'll have a boost for another 500rpms and stop at 6k,so I don't know if it's right or my timing is off,I have a solid idel,or I'm reading to much into it.1993 Ka24deCP PistonEagle Rods,Stage 2 Crower cams,(NEXT Mods)Stainless Steel Valves(Oversize)Brian Crower Dual Valve Spring + Seat + Retainer Kit
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
what kind of managment are you running?
youngun21a
Managment?? It's not turbo, It's N/A
H8tred
Sounds like a grounding issue, or your knock sensor is pulling your timing back. Are you getting any codes?
youngun21a
Nope code 55 only.
Florida240sx
my crower cams pulled to redline but I had boost with it.... What CP ratio for your pistons? Not checked your timing????
youngun21a
So I added some grounds and it does pull a little better,but have not test it at WOT.....yet I'll see in the morning on my way to work. and post results
youngun21a
So I had chance to try out with the grounds.Vid not that good but u can tell when the boost hits.on 5500rpmshttp://s82.photobucket.com/alb...A.flv
Modified by youngun21a at 11:40 AM 6/30/2008
Modified by youngun21a at 11:29 PM 7/5/2008
youngun21a
bump
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
knock sensor or the coolant temperature sensor.
brandonDavid
Car: 1992 240sx, 1992 D21
you must have put a vtec head on it, but seriously
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
youngun21a wrote:So I had chance to try out with the grounds.Vid not that good but u can tell when the boost hits.on 5500rpmshttp://s82.photobucket.com/alb...A.flv
Is your car a manual or automatic transmission?
i240sx
Car: 240sx coupe
don't shift yet wait until it almost hit redline...lol
240sxvaj
B-Metts wrote:you must have put a vtec head on it, but seriously
LOL i was thinking about the same thing. probably bought the wrong parts, are you sure those cams werent for vtec.LOL Vtec BAby!!!!
youngun21a
it's and automatic,lol good one,but I got all my parts from here.http://phase2motorsports.store....html
240sxvaj
my stock KA did that tooi was like WHOA V-TAKKKKKKK!
sometimes i would floor it on the up ramp and i could feel power like you said. it just happens every time i punch it hahahaha!
danielsan
Car: 1991 240sx coupe SE
mine did this a while ago, now it doesnt anymore for whatever reason. though its seems to be running a little better.
