Nothing works, please help.
silslider13
Car: 1990 Nissan 240SX Fastback
Okay, so i own an 1990 240SX fastback. I have a KA24E and well a few days ago my friend and i were messing around with it, and i had the battery out and everything, and i told him to put the battery back in, and he did but he put it in backwards, so the negative wire went on the positive terminal and vice versa. I then noticed that nothing worked, no power options, the headlights and tail lights work and same with brake lights, but the dash lights dont, and the radio doesnt, also the seatbelts and windows. I know it blew a fuse probably, but what fuse did it blow. Please help me i just got it running and i dont want to drive it without power options and lights.
Thanks in advance
574-240sx
Car: Nissans, Toyotas, Subaru
Start checking all fuses and relays. Start by the fuses/relay under the hood by the battery. After that move to under the kickpanel on the driverside. You may have to go to the junkyard to find some spares relays, some are pretty expensive.
kyle1911
Car: 1989 240sx xe coupe
You blew the 80A Alt. fuse
silslider13
Alright, thanks 574-240sx, and Kyle1911 for all your help, it is greatly appreciated. how much is an 80A alt fuse, and where is it located on the car, cuz i dont have the cap to all the fuses under the hood or anything like that. Thanks for all your help
s13sr20chris
fusible linkssometimes plugged into battery pos cablesomeimes in the fuse/relay boxtechnically the 80amp alt fuse is a fusible linkits like $9
