nothing but more problems
-=BoYo=-
Car: 1993 stage 3 300zx twin turbo
The idel of the car sometime will just climb out of no were to over 1000 what do you guys think it is you can look at my last posts were i listen some other minor problems that might have to do with it..
BMAR240SX
Car: 1993 Nissan 240S Coupe
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
vacume leak? idle air control valve?
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
Check for vacuum leaks
NSR240sxe
Car: '97 Kouki S14, '98 Sentra SE
sorry to here about ur prob. did you figure out what it is yet?
-=BoYo=-
I check for vacume leaks didnt find ne.next im gonna check the idle control vavle but does ne one know were it is ?
-=BoYo=-
umm i will get back to you guys with a huge post telling u guys what happend when im done, hopefully i fix all my problems, my cars on stands right now...
-=BoYo=-
i just checked my injectors from my ECU harness and no. 4 reads 24 ohms which is bad and no. 6 reads 93 ohms which is shot. This is why i think my car is runnin ruff. how hard is it to get to the injectors can someone plz list step by step???
and also my A.C.C valve is shot is there any way to rebuild it how much is a new one and how much are stock inkectors????
DustinZ
Car: 1990 Z32, rb25 s13, 1980 S130 10th anniversary, 1978 5speed fact ac s30, s2 rb26 on deck!
AAC is over $300 from nissan (block it off). To pull the injectors on your TT be very confident in your abilities and expect it to take at least 2 to 3 days if it is your first time. It is supposed to be a 9 hour job. In jectors are about $400 to $500 for new aftermarket ones. Good Luck.
DustinZ
-=BoYo=-
thanks does the A.A.C get clogged ?
