Notch Top Main Bearing Caps Differences... ????
japmaxs14
Basically I got two motors both Notch Top S14's but the Main Caps look different???
Can someone tell me what year these caps would be and why their different?
japmaxs14
I hope they didn't just sell me a S13 bottom with S14 Top.
is that possible?
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
My S14 caps look like the top one, all solid. Never seen S13 caps before though.
SxMachine
Car: Im on a horse
I dont know what that bottom cap is off of but my s13 cap looks like the top one as well
DuckyD
Car: 1995 240SX
SxMachine wrote:... my s13 cap looks like the top one as well
Ditto.
SxMachine
Car: Im on a horse
I mean since you have the bottom apart why not just replace them with the correct ones. They just might be the correct caps for that year or were replaced with a more recently available cap. It looks a bit bigger, gtir main cap maybe? Are you rebuilding?
japmaxs14
They also have different girdle, crankshaft.
I think I got an S15 Block, so far I found a picture of a SR16 with the same caps. and that motor was produced in 97-98.
japmaxs14
SxMachine wrote:I mean since you have the bottom apart why not just replace them with the correct ones. They just might be the correct caps for that year or were replaced with a more recently available cap. It looks a bit bigger, gtir main cap maybe? Are you rebuilding?
Yup,
Basically my first motor (the cap on the bottom of the picture) the oil pump failed and as a result #2 rod broke apart and created a hole in the side of the block.
So I purchased another S14 motor and I'm taking that one apart to get a fresh rebuild done and come to find out the bottom looks different.
Here's some pics of the damage. :gapteeth:
japmaxs14
Their also the same exact size just the one on the bottom feels lighter due to less mass.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
s***...
