IMColor »
https://forums.nicoclub.com/imcolor-u261877.html
Mon Jul 13, 2020 11:31 pm
Working on an 04 Pathfinder. Before I got my hands on it, the owner swapped out all hoses involved with the swirl control and vacuum system. He also swapped out the swirl control solenoid valve.
I've done extensive testing on the system and read through the service manual thoroughly, and here's what I've come up with:
The system isn't configured exactly the way the service manual describes, for example, the VIAS control solenoid valve on this truck has only two nipples, one that goes into the vacuum Reservoir and one that goes to the swirl control valve actuator. Based on the way the system should work, that doesn't seem to be relevant but I thought I would include it anyway.
I have confirmed that applying 12 volts across the terminals for both the swirl control solenoid valve and the VIAS control solenoid valve causes them to activate and act as they should. The problem is, these are valve ever receives the command to activate. I get 12 volts on one terminal, but never get anything on the other terminal for either solenoid. Not voltage, not ground, just nothing. That's regardless of RPM or engine temperature. It's Fly by wire , so there is no throttle position sensor.
For the VIAS, the service manual says there should be 12v on one pin, but makes no mention of what should show up on the other and has no procedure for testing it. It states there should be 12v on the y/g wire at idle and 0v above 5000rpm. Considering the r/y wire is fed 12v directly from the fuse, that means the solenoid only activates above 5000 RPM, and therefore that would be the only time that it moved the actuator. Which we know is not correct, because the actuator should move as soon as the engine starts.
Any insight anyone can offer would be greatly appreciated
