s13point5 »
https://forums.nicoclub.com/s13point5-u37946.html
Fri May 30, 2008 8:43 pm
so i did a search for high idle and every one i read, it seems everyone's high idle would be all the time. mine is different. after i have driven the car for awhile, the car starts the idle really high. i dont have a tach but im guessing 1500-2000 RPMs. after the intial start up and the cold start, the car idles fine. quiet and not high at all. it only starts idling high after i have driven her for awhile. i can shut the car off and turn it back on after 5 mins and the car will go back to idling normal again for awhile. i have the TPS adjusted correctly. i adjusted the idle screw on the IACV to idle a LITTLE bit higher because she was dying on me while i shifted into neutral while coming off the throttle. timing is right. no boost/vac leaks. its really bugging me because its making my gas mileage go to ****. i do have a Q45 TB. any ideas?
