just found out ca's use top feed injectors, cool.so i can use injectors for ka, sr...as long as their top feed??zero_gripS13 wrote:side feed injector wont work - top feed onlyka24de flywheel no work - sr will with sr clutch and s13 gear reduction starterka clutch will work if u remove one alignment pin or drill the pressure plate
they make top fee kits for sr and ka's, i could get the injectors from a top feed setup and they would work??zero_gripS13 wrote:ka/sr are all sidefeed.
u need skyline or dsm injectors or rx-7 for factory type upgrade.
yes one alignment pin has to be removed or u have to drill the pressure plate to accomidate the pin.
No, CA uses Low Impedence injectors......KA and SR are High Impedence. Unless you go stand alone you cannot use them.jrsink wrote:
