starkos14 wrote:i got the off-road package for the bilsteins and the vlsd. but the bilsteins still have too much body roll around turns and the vlsd never locks, even with the drift button on, sorry, by drift button i mean the "lock" switch thats supposed to lock the diffs, maybe its only the center diff but then i dont understand the point in rwd. and burnouts only consist of 1 wheel spining. also, this truck likes the drifty, so stiffer and lower suspension would be a lot more fun.
You have a 4x4 truck. It will not be a drift machine from the factory. It will have body roll in the corners. It does not have a center diff, but rather a trans case & a front and rear diff. The Bilsteins are meant to improve offroad performance, not on road handling.
IMO if you really want your SUV to handle well on the road you should get a 2wd model, and then go from there with suspension upgrades. I don't know of any 4wd SUVs that do not exhibit body roll. This isn't a Lotus (or even a 240), its a 4x4 truck.
Be aware that the reason your truck tows well is, in part, due to the way the suspension is setup. If you change that, it can affect how & how much the vehicle tows.
As far as burnouts & drifting, I don't even know why you would attempt to do that in a 4x4 suv.
