book-ends »
https://forums.nicoclub.com/book-ends-u3879.html
Tue Jan 11, 2005 5:39 pm
Well, it's actually two questions:
First, assuming you have a press or access to a press, why even bother getting heim joint units when you can replace the entire rear end bushing set with poly bushings for $36? I doubt I could tell a difference between polyurethane and steel when push comes to shove. Since the stock adjustable camber bolts for the RUCA's allow for upto negative 2 degrees of camber, the adjustability feature isn't worth $300 either.
Secondly, if I happen to replace them anyway with Battle Version or SPL units, do you leave the stock cam bolts in there and set both sides to a neutral level and then adjust the camber with the adjustable rod or what?
If you have them, you know what I'm talking about. Just curious.........
