ganma_ca wrote:Ok so def NOT the spark plugs Float, I had bcpr7s in ran somewhat decent thought hey switch to 6's maybe runs like complete crap after throwing those in, stalls and misfires out that wazooooo! So any other possible idea"s????
Not to sure but mannnnn I almost didn't make it home. Question though when a clutch starts to go out the symptoms would not involve the car sputtering out and dying would it????
Running 7s on most of you guys' CAs is not the answer. The 7s are colder and will foul much faster than the 6s (been there done that). If I'm reading this correctly and your car stalls out when wires move around, have you tried checking the codes on the ecu? I mean if the continuity falls short for a second, it registers a code. I can't remember, but are you using a KA-E AFM? THose harnesses might be 20+years, but I'm not making excuses for them because they are fresh and intact where they need to be. The problems are the connectors that are exposed to heat and weather conditions. You must inspect and/or clean/change as necessary as they are usually the problem. I haven't seen the suggestion yet for checking the ECU's codes, so gove it a swing and if I misread and that was already mentioned and done, disregard this last sentence. It's too many little things that can go fail, so get back with your findings and I'm sure you can get some constructive advice on the matter. And lastly, if you're not running on the average of 25psi of boost in 77+degree of temperature, take the 7s out as there is no need for them (Your choice)
