RustspecS13 »
https://forums.nicoclub.com/rustspecs13-u75597.html
Tue Jan 19, 2010 7:21 pm
I have a RB20/25 down pipe for sale. It fits the stock elbow that comes right off the turbo and goes to a stock location cat/test pipe. I made it myself and it tucks pretty close to the chassis.
I'm using a Mckinny mount kit and stock subframe in my s13, and that's what its made for. I'm not sure how well it would fit with a mount kit that uses a r32 subframe.
The only reason why I'm not using it is because I upgraded my turbo and I cant use it. Its made with 3/8in Vibrant flanges and its 3in diameter, with a mandrel bend, and the piping and flanges are all Stainless steel.
I don't know why you'd need a cat back made as the cat back is universal to any engine. The only thing that changes is the turbo elbow and down pipe. Basically between the engine and test pipe/cat.
I really doubt the R33 down pipe will work, and even if it will there might be clearance issues. A custom cat back would be more money then a custom down pipe, as the cheapest one on e bay is $160 plus shipping and a shop to modify it.
Good luck on the swap!
~Alex
