gingerbredman wrote:The forum used to be much more active back in the day. I actually haven't logged in almost 10 years, but through the fire I'm back. Anyhow, I can't really offer any SR-specific advice as the most I've ever really done was visually look at one. Now, with those 4 injector wires, if I'm reading what I think I'm reading, then they'll have constant power with the ign. switch. If that's the case, that won't work at all as the ecu won't be able to control them from there. The injectors operate on the pulse signals that the ecu sends, I would say with some certainty that too long of a charge at the injectors could burn them out so be careful in your testing.
Only way I really know of testing injectors is like you did, turning the engine over while having a test light lead on an injector should indicate that it's working properly, by the pulses of light.
The injectors I presume to be wired up correctly now having 4 wires to the ecu in proper pins and have 12v constant power going to them. When I was working on it on the weekend the constant power wires were wired to the actual ignition switch. I also got it to quickly fire up for a second or two tops from gas being in the cylinders but quickly died out from no injector pulse. My injector ground wires are going to the intake manifold and I ripped apart the harness while its still in the vehicle and I made sure every connection was soldered, even soldered a bigger wire for the injector ground to see if it needed more ground but still no luck. I haven't taken an sr wiring harness apart before and the guy I got it from locally is known to sell s*** parts (but we are friends so I wouldn't think he'd f*** me over... Doutbing that now). It seemed odd that the ECU's constant power and alternator feed return would be butt connected to the 12v constant for the injectors while having another wire go to the big grey plug for the body harness. That's why I cut it and re ran the constant power, alt return, and big grey plug wires to constant power. And re routing the injector constant to the ignition. I have been busy with school this week as my final exam is tomorrow so I haven't had time to fiddle around with the car but I'm planning to change the injector constant power to maybe a on/off toggle switch.
PapaSmurf2k3 wrote:Yup. Verify fuel pressure is correct. You know you're getting spark, but do you know if your timing is correct?
A quick and easy test to see if your spark is good (and you're getting too much fuel) is to pull the fuel pump fuse and crank for a while. It should clear any excessive fuel and start the engine for a few seconds. If that happens, you know you're giving her too much.
I will verify fuel pressure this Friday/weekend to make sure it's good, but it should be good sense I got a new aem high flow fuel pump. I also read that the stock fuel pressure regulators can crap out once a high flow fuel pump is installed, and way to see is pinch off the fuel return (don't know how true it is so feed back would be sweet as I only found 1 thread saying so.)
If anyone had an fsm for a 180sx sr that'd be cool, I know the cars a kouki 98 but motor swap is a red top. I've been reading other fsm's but closest one I can find in English is a 200sx ca18, which is alittle help until diagnosal of electrical system cause wire colours and some ecu pinouts are different and I kind of want to re trace every single wire known on the car (other than lights) just to make sure it's all good cause I do have a couple wires cut under the dash and by the jdm driver side engine bay fuse box (red wire). I also want to re word one of my previous posts, the only way I can get the injectors to click is by using a test light and back probing either one of the wires. I did that a few times to each cylinder to see if the motor can actually fire and that's when I had to running for a second or two tops (no throttle response tho sense injectors weren't firing).
The guy I bought the rolling 180 shell off of said the only problem he has when getting his motor to run was the same no power ecu but I copied exactly what he did but still no luck (what was done was stated in first post). Sorry if I am repeating myself, just making sure all information is said for best help. Thanks for replying and giving me some help, I'll be definitely giving the suggestions a try this weekend. I also might break down and waste more money on a ecu or wiring harness.. Ecu might not be sending the injector pulse to squirt (sends it by grounding out if I'm correct)
