Not Starting.....
JC87HB
Car: 1987 Nissan D21 HB
Ok... so i wake up to go to school and my truck (87 HB) starts. I get to school and the day is well. Unfortunantly i go to my truck after school to find that it wont crank. After a few tries it cranks and i go home. When i get home i turn it off and try to turn it back on to no avail. it make a Click........click click click click noise really rapidly after it clicks once. Now the battery is dead although it will still play radio. I can jump it off and itll crank. My question is is it my Alternator? The battery isnt even that old.... I Once had a short but that was do to some fabrication and i cleard that up easily. Please i need some help with this lol.
nismopu
Car: 1987 Nissan 300ZX
1997 Nissan Maxima
1976 Datsun 280Z Turbo
clean the corrosion of your terminals and check all connections, peace.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Yup. And many parts stores will test those parts for free - the battery and alternator.
Would it start after being jumped?
JC87HB
After we jumped it off to start it we turned it off after a couple of minutes. It would NOT start afterward
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Could be a dead spot inside the starter, loose connection, corrosion as these guys have said.
nismopu
1997 Nissan Maxima
sounds like a dead battery, or bad connections. do you have access to a voltmeter? you can check to see if your charging system is working and many other things, like dead batteries or batteries that hate holding charges. peace.
vbdenny
Car: 2001 Frontier
I'll second the dead battery call. Classic symptoms of a battery with a compromised cell. If it is more than 3 years old, replace it. Get one at Costco for about $50
