Not starting...sometimes.
YuNg1's_240sx
Car: 1995 Black 240sx SE
Hey guys, I am having trouble starting my car when it has sitten cold for a couple of hours. I turn the key and everything lit up but the engine does not crank. I sometimes hold it but still nothing. Only after the take the key off, and wait about 10 seconds, does the car start. I was thinkin maybe the fuel pump or something of the sort... could you guys decipher what the problem is? ThanksArash
rms13Mike
Car: 1992 Nissan 240sx Fastback, 2005 Toyota Corrolla S, 1990 Toyota Camry, 1998 Honda Accord LX-V6
i had the same problem but i think mine isn't dependable on coldness, i was told it was the starter so i changed it and for the past 4 months it happened once, but other than that it works fine, maybe starter solenoid?
doesn't really help but just wanted to tell you my experience
dfitzg
Car: 95 240sx
bump
having same issue... wont start after sitting for a few hours
FRnIsmO
Car: 240sx fastback
sounds like some direction there, you know how to check if starter works guys?
rms13Mike
FRnIsmO wrote:sounds like some direction there, you know how to check if starter works guys?
try hitting it, or maybe take it out to get it tested
