A few weeks ago I tore into my z and did some work. I had the plenum off the lower intake manifold off. Deleted the egr and replaced the knock sensor and sub harness. New injectors. Had the front end all tore down to the crank and ca
Shaft doing a whole 120k timing kit and UR underdrive pulley and accessory pulleys. New seals on everything. All new fuel line and water line and vac line. Plenum coolant delete. I did the works. I also painted almost everhthing. It looks good. It just won't start. It will crank and crank but never fire. Any ideas??? I checked that when the crank pulley mark was at 15 before TDC the number 1 piston was at the top. So timing should be correct? I know I'm getting spark. I just put a new battery in last night but it seems to be turning over slower than before. I'm just out of ideas. Also the exhaust kind of goes thump thump thump and it gets louder if i pump the gas. Could it be wiring? I had a problem in the past where it would start and then bog and die and then not start again till the next day. Maybe a vac leak? I'm going to put my vac leak tester on today and pressurize to check for vac leaks. Any other ideas would be greatly appreciated.!!! Thanks!
