not spooling properly?? idk
Stratokat
Car: 1992 240sx Coupe
finished up my sr swap, and i ran into an issue.
there are NO BALLS attached to the sr, but it was running fine in another s13 a week ago.
when i mash on the pedal nothing happens, it slowly accelerates, then some back fire, if i lightly press the pedal, no back fire, and slowly accelerates, but still, it feels like its a 1.0 litre engine... and NEVER hits max boost, if any lol.
ive had a few very good minds take a look, and all vacuum lines are properly connected... maybe a leak? where tho. where would the leak be to cause this sort of problem.
Chris28
Car: 92 s13 KA-T
Double check all your piping and hoses, whether it be boost or vacuum. Also make sure your wastegate is hooked up properly. If it's stuck open you aren't going to see any boost. You should at least hear the turbo spool and your boost gauge should show boost, so it has to be a leak somewhere.
Stratokat
Chris28 wrote:Double check all your piping and hoses, whether it be boost or vacuum. Also make sure your wastegate is hooked up properly. If it's stuck open you aren't going to see any boost. You should at least hear the turbo spool and your boost gauge should show boost, so it has to be a leak somewhere.
going to hook up the boost gauge tomorrow, ran out of time today. and yeah, i hear it spooling of course, and the bov working...
im going to check every possible hose/tubing...
Chris28
Car: 92 s13 KA-T
Hmm, that's odd. How does it run otherwise? If it's a boost leak it would run like crap, which is what it seems to be doing. I bet you have a boost leak somewhere.
Stratokat
it idles perfect... just honestly feels like there are no balls anywhere throughout the power band!!!
best way of checking for leaks? =/
driftneil
Car: A pile of cars.
Stratokat wrote:it idles perfect... just honestly feels like there are no balls anywhere throughout the power band!!!
Starter fluid, spray your piping and if it surges up....you have a leak! wouldnt recomend shooting the hoses with it, might eat em up.
Stratokat
two words...
Blown Turbo
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
Or your timing is off, the popping and backfiring is a givaway to that. Turn your CAS and see if that helps.
Stratokat
blacksrjdm wrote:Or your timing is off, the popping and backfiring is a givaway to that. Turn your CAS and see if that helps.
i'll check it... but im pretty sure the turbo is the main issue. very excessive amounts of blow by[theres even oil in the intake], i dont hear it spooling any more. and the wastegate opens up after the smallest bit of pressure accumulates and doesnt let the car accelerate
blacksrjdm
OK, then buy a new turbo then.
And if the actuator is opening with no pressure then you might have a blocked up vaccum line too.
Stratokat
so the problem wasnt the turbo...
gah... im so frustrated. please, i need help... its acting worse than ever.
the car cannot hold an idle unless i give itgas for a few seconds right after start up, then when i try to drive it, i can put the pedal to he floor and it just doesnt respond.
driftneil
Stratokat wrote:so the problem wasnt the turbo...
I know you sid the maf is good, but sounds like it to me.
Ghast
Car: 1993 240sx, 2002 Lancer ES, 2006 350z Enthusiast
How hard was this engine run before it was given to you?
Xdisaster240sX
Car: S13 Hatch, R32 GTS4
What about fuel. Like the fuel pump,fuel filter, or fuel injectors? Possibly your catylitic converter
Stratokat
driftneil wrote:I know you sid the maf is good, but sounds like it to me.
i was just thinking the same thing
