DriftX »
https://forums.nicoclub.com/driftx-u61933.html
Fri Oct 12, 2007 8:20 am
Finally the car is moving under it's own power and I can drive it for the first time in months. As like with all swaps, you always have your problems. Wiring is 100% and everything is hooked up.
So my problem is this, the car idles fine and runs great under minimal boost and under 3/4 throttle. When I get the revs up some and go into boost under WOT, it wasn't to break up real bad, sputter and buck.
So now I need to check vacuum to the engineBoost leaksfuel pressureinspect spark plugs/clean/regapinspect coilpacks for damagerun some soapy water on the intake to find a possible bad intake gasketpossible throttle body gasket leakPossible slipping clutch - but that wouldn't effect vacuum as it's still only reading 14 or so. Need to rebleed dampener box and see if that helps.
I am also getting compressor surge (whatever you want to call it, not starting a debate), my vacuum is hooked up to the bypass valve, so I think it's shot
So anything that you rb20 guys have had problems with in the past, please feel free to chime in and let me know what you did to fix it. I don't have tons of time to work on the car, so If I could narrow down the problem some that would be great!
