how much pressure it takes to get it to blow off i think its set a little harder than needed so it opens only momentarily. Its all in the math .hahahahaOM3GA wrote:a certain way? wtf haha.
If people took the time to set the tension on the spring properly, or would just stop being cheap bastards and buy a good quality and designed bov this would be a non-issue. But I guess some people would rather be lazy and/or save a few bucks so they can kill the bearings in their turbo.safin wrote: compressor surge during light driving because the spring in the BOV is set so it only opens at high boost. Isn't this like very bad?it sounds safer to just run it to the atmosphere and mess with the rpms so it doesn't stall
There's always a big debate on this. Ball bearing turbos can withstand more turbulence from compressor surge compared to journal bearings. Just the way they're designed and the way the turbo shaft sits inside the bearings. Ball bearings also don't require the thrust bearings(which are usually the weakest part in the turbo)like journal bearing turbochargers do. The question though is, "How much is too much compressor surge?". Lots of people have ran their turbo and bov the way you mentioned for years without any issues, but then that leads to the how much is too much question. Some bov like the new HKS one doesn't have an adjustable screw IIRC. That's why I got my Synapse bov. I'm going to recirculate this one and see how it works out.safin wrote: compressor surge during light driving because the spring in the BOV is set so it only opens at high boost. Isn't this like very bad?it sounds safer to just run it to the atmosphere and mess with the rpms so it doesn't stall
Your right, not having a Blowoff Valve probably won't kill your turbo the first time you let off the gas completely after being at full-boost at WOT. However, you are wrong when you say that all it does is make a fart/lazer noise and decrease boost response. It will help to prolong the life of your turbo for all of us who don't have the money to just go buy a new one whenever we want.ILoveMyRHS13 wrote:It does NOT kill turbos. All a blow off valve does is make fart/lazer noises when you shift and decrease boost response. Everyone needs that, right?
I've been thinking about this for quite some time also, i saw that post as well.ILoveMyRHS13 wrote:sure if you really love your BOV, we will weld a flange for you but we recommend you dont run a BOV for drift because you dont need to release boost while modulating the throttle for counter steer during drifting, this HMIC concept is all about response and the BOV is not
Factory's waste their money putting in BOV's on their production turbo vehicles also correct?ILoveMyRHS13 wrote:Oh people; you so sirry.Blowoff valves are the biggest waste of money on the earth. Recirculating isn't bad, but then what the hell is the point? Sell it to Captain JDM Pants for billions of dollars (just like you did).
It does NOT kill turbos. All a blow off valve does is make fart/lazer noises when you shift and decrease boost response. Everyone needs that, right?Modified by ILoveMyRHS13 at 12:42 AM 12/28/2009
Not too many manufacturers use atmospheric BOV's, they use diverter valves.duffman1278 wrote:
Thats what the SR originally came with correct? All we try to do is keep that system by buying aftermarket valves. Its all about how the person installs it which deviates whether or not it is done properly.ILoveMyRHS13 wrote:Not too many manufacturers use atmospheric BOV's, they use diverter valves.
Someone correct me if I'm wrong, but Nissan used atmospheric BoV's on some laurels and cefiros with the rb20det.ILoveMyRHS13 wrote:Not too many manufacturers use atmospheric BOV's, they use diverter valves.
And yes, most if not all turbo'd SR's came with a diverter valve, but by definition a re-circulated BoV is a diverter valve. All depends on how the plumbing is done.OM3GA wrote:Thats what the SR originally came with correct?
