Last week, a Motiva terminal in Newark, N.J., that disperses ethanol-blended gasoline had to replace its supply entirely after water seeped in, prompting complaints from drivers.
“Customers were pulling away and not getting very far,” said Stan Mays, a spokesman for Motiva, a joint venture of Shell and Saudi Refining Inc.
He said the problem has since been fixed.
The Northeast — with the exception of New York and Connecticut, which switched to ethanol last year — and Texas are the two regions most affected by the switch because of their heavy use of MTBE-blended gasoline. Particularly affected are Philadelphia, Baltimore, Washington, D.C., Richmond, Va., and parts of Delaware and New Jersey, Sundstrom said. Parts of Texas had shortages two weeks ago.
Washington is the fourth state to enact an ethanol requirement. The other states are Minnesota, Montana and Hawaii. ....Missouri
And the government warned you:
http://www.eia.doe.gov/pub/oil...6.pdf
