rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Sat Apr 08, 2006 4:12 am
You don't "need" anything to slide or feel your butt pushed back in the seat (which is caused by torque FYI).
My buddy has a SR Redtop with stock turbo, fuel, and the same bolt ons I have (he has a FMIC, while I have a ARC SMIC). We also have the same turbo (Garrett T25G .80A/R) and on the highway, he at 7psi, me at 8psi, we were dead even. Reaqlly, the motors are very similar when compared to power production, although the SR sees more torque down low, but not so much more that you can throw a big fit about it. SR guys like to trash talk about torque figures, when neither eninge is really making large #s in BPU stages.
Now, as for the 40+psi: Really, any motor can do that on the right fuel and with the right build components. I've seen 13BT 6 ports swallowing 46+psi, so that is kind of an unfair qualifier.
Also, if you want to compare a KA24E-T to a CA, the CA will be much revv happier, will take more boost on the stock bottom end, and will be an easier motor to build up on. Plus, do you really want a SOHC?
Every time I get in my car and crank the boost controller to 10psi I am impressed with the performance.
