Not getting pressure ?!
KayteesQ45
Car: 1997 Q45
So car misfired and stalled, wouldn't start up. Had to get it towed. I so far replaced the pump, at first before I swapped relay the the fuel gauge didn't work. I changed out the relay under the dash and the fuel gauge started working but not the right fuel level. And it doesn't seem to get fuel pressure. The only way it is starting is by starter fluid. But then it instantly dies. I took pump out the tank and no gas was in the lines no pressure still. The fuse was okay, and like I said I changed a light green relay under the dash. Please help. Idk if my post make sence. Was long tiring day lol. Let me know thank you !!
goody90q45
Car: 1992 Infiniti Q45 (sold)
Welcome to NICO KT. I'm not familiar with the 97Q fuel pump set up but I think it's going to be the same as the 90-96 Q. Unless there's a broken wire on the fuel pump assembly (we've seen this) then I would say that you have a problem with the FPCU (fuel pump control unit) which on the 90-96 Q is mounted on the underside of the rear parcel deck above the fuel tank. You'll be able to see it from the trunk. To verify that the FPCU is the problem, unplug the connector and run a jumper from the connector pin to ground. The picture shows which pin to attach the jumper to and the FPCU is in the background. If the engine fires up with the jumper installed then the FPCU is bad.
For the improper fuel level reading.... That signal comes from the sending unit which is part of the assembly that was removed from the fuel tank to replace the pump. It's easy to damage the unit, or break a wire during the fuel pump R&R. Since you were getting the correct level before the change out I would guess that your unit has been damaged.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
start with measured fuel pressure (no guesses please) at the RAIL.
filter (when was it changed last??) is above a plate just in front of right rear tire. on frame.
