480sx »
https://forums.nicoclub.com/480sx-u50548.html
Thu Jan 25, 2007 4:47 pm
[QUOTE=nightkid86]clutch pedal squeeking has nothing to do with it, you just need to grease up the spring.
On a 95+ its not the spring that sqeeks its the brass fitting that goes inbetween the fork/rod that connects to the master cyl. and the clutch pedal. On a pre 95 im not sure.
Also check your pedal adjustment, as clutch's start to wear you can adjust the pedal sometimes to get some more life out of them.
