Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Mon Mar 16, 2009 2:59 pm
I have tried to help in the other forum, but can't tell for sure what the issue is either. My guess is that there's some confusion as to if the wire that needs to be connected to the Kenwood unit should be connected to a lighting wire that is controlled by the dimmer, or if it should be connected to one that is always at 12V anytime the park lights are on.
If I'm right about the question... does the Kenwood unit have two connections for illumination? What does the installation guide call for... a 12V when lights are on wire, or one that varies it's voltage with the dimmer control? In either case, I would think you should be able to probe an illumination wire and measure it's voltage with a multimeter. If it varies with the dimmer, you know it's controlled by it...
Heath
