Texas240sx »
https://forums.nicoclub.com/texas240sx-u5158.html
Tue Oct 14, 2003 10:05 am
I have been reading post like crazy for the past month! I got my 89' 240sx to start with a 96' ka24de, 96' ecu, 96' distributor, and 96' harness! It took me a while to figure out the wiring, but I finally got spark at the distributor. I don't think I am getting fuel to the engine! I have the black/pink stripe fuel pump line connected to the correct spot on the 96' ecu, so I know it's connected. I took off my fuel line from the fuel filter and it would spit out gas whenever the battery was connected. Just in case I went ahead and just put in a new 300zx fuel filter. When I spray starter fluid into the intake it starts and then shuts off due to no fuel. Does anyone have any ideas or suggestions on the fuel system. I have the fuel filter line connected to the tube that leads between the injectors and the second line which I believe is the return line connected to the tube closest to the fire wall. Maybe I have them connected wrong? Can someone please explain it to me? Thanks!
