Not getting any action on cylinder 4
Roginooo
Car: Nissan S13 vert
The cylinder number 4 is not giving a good consistent spark like the other and I already check Distributor cap, Ignition coil, spark plug and wire they are all good. Could the ignition module be doing this? What else should I check?
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
I would say that's iffy only because the coil doesn't care what cylinder is firing, it's only looking to discharge at the right time. Did you test the #4 wire with a tester?
Roginooo
The injector was bad. fixed
