180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon Dec 04, 2006 11:13 pm
if it's #1 and you've got spark, it's gotta be fuel. Give the injector plug a wiggle and see if that helps it out a bit. Since you've an s13, I'm going to assume yours are pretty corroded by now. Either that or you've got a stuck injector if there's no fuel getting dumped after you've cleaned and tightened the injector plugs.
