not charging
moneymike
Car: 1991 nissan d21 hardbody
hey i have been having some problems with my truck
got a new battery new alternator new fuses and relays
now the problem is the alternator isn't charging the batter ive gone though about 3 batteries and just keep spending money on this lil problem that i cant seem to fix so if anyone has any thoughts or knows whats going on let me know asap :o
i will be posting some pics of my set up soon if you remember i boosted the truck :chuckle:
RT22
Car: 1991 nissan hardbody
if you have had alternator checked and it is putting out a good charge, then the problem is the wiring. If alternator is good you are losing the connection from alt. to the battery, that is all it can be. Now you must track the charging signal from the back of alt to the battery and see where you are losing the voltage. That electrically is all it can be again if you are 100% sure alt. is good.
moneymike
is it possible to just rewire it so i have a ground and a wire straight to the batt.?
moneymike
with a inline fuse
RT22
Check the wiring schematic if you repull wiring to make sure you rehook all connections.
dvdswan
check the fusible links at the battery.
truckboy
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
did you just try one altnerator, and have you actually had it tested? Where did you get it? Autozone / Checker, etc. are notorious for selling bad reman'd alternators.
Most parts stores can test them either in the truck or on the bench. Before you keep sinking money in new batteries, pull the alternator and have it tested.
moneymike
i got the problem fixed now and didnt need a new battery or alternator, for some reason my b+ wire that went from the alte. to the battery was no where to be found. it most likely got burned out or something i would assume. all i had to do was run a new b+ wire from the alte. to the batt. then bam problem solved
