HELP! not charging after starter replacement
93s13rookie
Car: 93 s13 and 90 q45
Over weekend I changed starter on 93s13 and ran fine one day then last night wouldnt start, saw one of the battery terminals was loose locked it down then drove half way home car dies, replaced alternator 10 months ago, battery about 18 months ago, finally got to this starter not it wont charge battery, PICKED up a new battery in case the old one was drained beyond recharge... Need some help bad. :ohno: :ohno: :ohno: :ohno: :tisk:
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
Get your alt. checked out or even just use a multimeter on the battery with the car running to see if its charging 14.XX volts or so.
