I would add them if it made a difference to someone overall goals..but it really doesn't...the choice of suspension, and settings are given by their run of choice (street, drift, road race, autocross, etc)..so that's covered in the basic "attention" sticky.chmercer wrote:you want to run drag slicks or somthing? thats kind of what it sounds like.
what camber do you run? what caster do you run? do you want to modify your fenders? what tire size do you want to run? what suspension do you have?
^^^somone should add these questions to the faq of somthing.
lol, cmon man, what do you take me for. i just included it since large amounts of positive caster can affect wheel fitment (IN THE FRONT).Exar-Kun wrote:charlie, the rear of the car doesnt have caster.
Thanks, but the whole reason I was inquiring is because the car is an hour away getting painted and I wanted to go ahead and order the wheels so they will be here when it is done.crzycav86 wrote:Here, I'll help you help yourself...
Your stock wheel specs are 16x6.5 +40
Use the wheel offset calculator(found in wheel faq): http://toy4two.home.mindspring.com/offset.html
Plug in some numbers for your size and take some measurements on your car.
Good luck
That is the whole reason I asked. I searched for over 2 hours and I couldn't find a straight forward answer for the question I asked. My question was pretty straight forward could have been answered easily. Some poeple on this forum are good at making mountains out of molehills.SmithSR wrote:Fitment issues always come down to What do you want to do with the car? Will you hack the car and it's alignment, just to fit a JDM wheel from Option video? Does a sunken wheel look girlie-man? Is maximum grip more important than having 10" wide mesh wheels from aforementioned Option video? Always remember that R compound is available in smaller 16" sizes too..
Oh well, I knew it was going to happen. For those that merely meant to help, Thank you.
Wide wheels with a correct offset (read: no drifter flush, OMG my wheel sticks out 10" it's soooooo JDM!) shouldn't have too much of a degradation. The centerline is still within the norm.Exar-Kun wrote:IMO a 17x9 is the widest rim anyone should be contemplating putting on any S chassis, from a handling and suspension/steering geometry standpoint. you don't want to deviate the centerline of the contach patch too far from its stock location otherwise you WILL encounter problems. and even a 9" wheel on the front is going to cause issues as far as that stuff is concerned...
the problem is most people1. don't care2. don't want to learnor3. disregard logic
Actually I meant 17x8 in the front, but this 240 will never see a road course anyways. This car will be a street car with drag racing as it's main purpose, therefore I want as much rubber on the ground in the rear as possible. The front doesn't matter either way, unless you consider the added weight of the wider rim and tire (but I'm not really worried about that).C-Kwik wrote:Without even getting into offsets, why do you want to run such a huge difference in stagger? I mean, I have no problem with you running a 10" wide rear wheel(I wanted to at one time), but couple it with a 7" front wheel and there is a difference of 3 inches in treadwidth. The only cars I see with that much of a stagger difference are Porsches and those are Mid/Rear engine cars so they tend to need it. And keep in mind they have rear weight biases close to about 60%.
If you want to be good and consistant at drag racing, get a spare set of 16x8.5 Z32 Turbo wheels and put M/T's on them.tl1000sga wrote:Actually I meant 17x8 in the front, but this 240 will never see a road course anyways. This car will be a street car with drag racing as it's main purpose, therefore I want as much rubber on the ground in the rear as possible. The front doesn't matter either way, unless you consider the added weight of the wider rim and tire (but I'm not really worried about that).
