Thanks fellas! The 600hp figure is about where one needs to stop or the little CA is going to be a costly headache. And unless you just want bragging rights, there's no real need to go further unless you like trying to find a gearbox that can handle more power. Some of you guys have a little more enthusiasm than I do at this time, so take some lessons from the more knowledgeable folks on our forum, especially
float_6969 and
themadscientist and that will save you the headaches as well. Remember, if you don't spend the money needed to achieve your big goals, you should stay in your lane or you will have a bad accident. Honestly guys, 600whp out of the CA18DET in either an S12, B12, S13 or KN13 chasis is just ridiculous. And for the novice driver in the RWD variants, you will kill someone or get yourselves killed; trust me on this one. Anything more is just a dyno queen or a stupid burn-out machine and hopefully that's not what you are wasting money on. My CA powered coupe has cold A/C, P/S and 536 ponies stomping on the ground at my disposal. Honestly, I'm scared of the car which is why I just drive around the block to keep the battery charged and the oil circulating. Sideways, take notes and get that newly built engine in your car. Engine management and turbo selection is key
. Good luck and holla if you need me.
