Not again: 4WAS !
InfinitiM37
Car: 2013 Infiniti M37
In the past I found several times great help for a project that was just much easier after seeing someone doing it or just talking about it on the internet ! That is where forums or you tube come in . I never contributed to that until now . I really felt like if it just helps one person it is worth it . So here it is: Many posts talk about when the 4WAS light comes on our rear wheel steering cars to clean/replace electrical connectors, clean the grease out of the actuator motor etc. ! After doing all that without success I finally found that the Carbon Brushes where just a smidge too short ! At first I could actually not see it but I had that feeling...So I removed the brushes out of the holder and with a Dremel tool ground the slot where the wire and the slot where the spring is riding in a little deeper . After assembling the motor I tested it by hooking up 12v DC from a batterie and by reversing the leads I could see that the motor spun in both directions ! After installing the Actuator and test driving the car the light stayed OFF ! This proofed to me that the brushes did not reach the armature but intermittently by bottoming out in the slots ! All I need to do now is buy 2 new carbon brushes and hopefully they will last another 100k miles ! I love my M37 ! I hate it for all the ones that paid big money for replacing the hole steering rack when in fact these brushes are a wear item and Infiniti should offer replacement actuators ! Hope this helps someone and good luck !
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
These guys have a huge online brush collection, rebuild motors, and can even rewind bad stators and armatures. There's pretty much no reason to let unobtainium motors ruin your day:
https://eurtonelectric.com/
Ilya
Moving to the correct forum as it was posted in the M35/M45 forum.
InfinitiM37
Great info on Repair and Parts ! My point is that I never saw [just didn't find] a post where someone got into the brushes and got it fixed by installing new [longer] ones ! Any car mechanic should be able to fix this before talking the owner into paying thousands of dollars for replacing the hole steering rack ! That includes Dealerships .
VStar650CL
Technical Expert
Back in the old days dealerships routinely rebuilt starters and alternators instead of replacing them. Absolutely no one does that today. Maybe if you supplied the brushes and found a knowledgeable old timer like me, but otherwise, it's a great DIY job that you'll never get a shop to do for you.
