Not A Bad Head Gasket 2.4 ?
mrecoolgar
Car: 1990 Hardbody Reg Cab 2WD 2.4 5SP
Working on my 1990 4x4 with 2.4.
It was parked by the previous owner due to coolant in the oil.
I verified the coolant in the oil as well as some oil in the coolant.
Plus the 2 or 3 times I had it running it smoked heavy and white.
I pulled the head today.
Weird thing, the head gasket appears fine as well as the head.
I didn't look under the head gasket which is still on the block.
Does anyone know another area to look for regarding this cross contamination?
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Cracked block?
seang
Car: Ford Fiesta ST
Another area to consider is the engine's front cover. After the timing chain guide has failed, the chain rides across the aluminum front cover and eventually wears through into a coolant passage. As for the smoke, some of the nasty mix may have gotten pushed through the PCV system into the intake tract, I'm not sure though.
mrecoolgar
Thanks guys, that's the kind of info I was hoping to get.
I won't get back on it till next Monday.
RT22
Car: 1991 nissan hardbody
my nephew had timing chain do just that bust into coolant passage.
mrecoolgar
Thanks.
Anyone have a good one to sell?
mrecoolgar
Sure enough it was from chain wear.
mrecoolgar
And this is all that was left of the chain guide.
