nostart 89NX
northstar ninja
Car: 74 260Z, 92 240sx hatch.
ok, im at work and sorta stumped on this one. its a ca18de nx, with a no start condition. car is getting fuel, its getting spark but still doesnt run. customer says was sitting for a while while his daughter was at college. we put new fuel in the car, and im assuming the injectors arent clogged as the plugs are wet with fuel.
MaximA32
The spark plugs aren't supposed to be wet with fuel. They should be dry. I would replace the cap, rotor, wires and the plugs. It sounds like you're not getting spark which is why the plugs are wet.
northstar ninja
they pulled out two of the wires and nick zapped himself pretty good i'm told. there is no distributor, its coil on plug.
MaximA32
What color was the spark? If it's a white color, it's good. If it's orange, the coil is weak and needs replaced.
northstar ninja
he says it was white...
MaximA32
Ok. Did the wires look old or anything? Honestly, I would just change the plugs and wires if it's been sitting as long as ou say it has. It's relatively inexpensive and easy to do.
northstar ninja
i think its a tming issue, possibly a crank position sensor/ camshaft position sensor... my last guess is the ecu itself.
NM50
Car: 94 D21,98 03 hummer H2,66 311 CA18ET ROADSTER,94GEO METRO pimp mobile
Lack of compression is a common failing in CA16DE Pulsars,but check for good fire on all 4 cylinders.
