NOS with ECU tune?
Xero
This has probably been asked before, but I can't find it. Can you run Nitrous with a JWT ECU tune? I hear that if the timing is advanced, that it's bad for the engine if nitrous is put into play. So does the JWT tune advance the timing? thanks
Exar-Kun
Car: 2005 350Z
how exactly would changing the ECU alter the timing?
I thought you had to do that manually. either way, if you TELL JWT that you'll be running nitrous(and how much) they can actually make you a comptuer program for it.
-chet
NISMO24096
jwt has its own computercontrolled nos kit. it actually runs two different programs one for when you are using nos and the other for when you are not using nos, im sure if you want then to add that to your ecu they can do it for a charge, im currently running there 65shot computer-controlled setup and it droped me almost a full 2 sec in the quarter mile. and no problems with the system it a great setup....
